Example: KRYPTON TH with Sync junction and sync via IRIG to XHS --> XHS is limited to 10 MS/s
Why?
This is due to Sample rate divider capabilities. KRYPTONs have only certain sampling rates supported (the ones that are in dropdown or defined in the specs sheet).
SRdiv = 2^n * 5^m.
Only certain sample rates can be calculated and compatible with 15 MS/s.
ECAT devices don't have those compatible numbers supported, so the SR of the XHS is limited to 10 MS/s and then SR of each device suffice the formula.
What about if I connected Dual Core, HD or HS SIRIUS USB slice and SIRIUS-XHS, do I face any SIRIUS-XHS sample rate limitations in this case?
USB devices have more SR supported, so if you want to run SIRIUS-XHS with 15MS/s, the HS will be limited to 937.5kS/s
Calculation:
15 M / 1 M= 15 --> SRdiv 15 doesn't exist, the closest is 16.
15 M /16 = 0,9375 M
See the list of the compatible Sampling rates:
srdiv15000000 / srdiv = allowed Sampling rates
115000000
27500000
43750000
53000000
81875000
101500000
16937500
20750000
25600000
32468750
40375000
50300000
64234375
80187500
100150000
125120000
128117187.5
16093750
20075000
25060000
25658593.75
32046875
40037500
50030000
51229296.875
62524000
64023437.5
80018750
100015000
102414648.4375
125012000
128011718.75
16009375
20007500
25006000
25605859.375
31254800
32004687.5
40003750
50003000
51202929.6875
62502400
64002343.75
80001875
100001500
125001200
128001171.875
15625960
16000937.5
20000750
25000600
25600585.9375
31250480
32000468.75
40000375
50000300
62500240
64000234.375
78125192
80000187.5
100000150
125000120
128000117.1875
15625096
16000093.75
20000075
25000060
31250048
32000046.875
39062538.4
40000037.5
50000030
62500024
64000023.4375
78125019.2
80000018.75
100000015
125000012
15625009.6
16000009.375
19531257.68
20000007.5
25000006
31250004.8
32000004.6875
39062503.84
40000003.75
50000003
62500002.4
78125001.92
80000001.875
97656251.536
100000001.5
