Description of the problem
How to solve the problem if you can't change the offsets for the sensor?
Description of the solution
This problem is solved in a few steps.
1) Go to Analog sensor editor
2) Then change for sensors Fixed offset and Save changes to the database.
3) Set the correct offset in channel setup.
