DewesoftX supports High DPI settings which are enabled by default. If you want to disable them, you can use the following instructions
- Right click to DewesoftX *.exe icon and then click to Properties
- In the second step you will click to "Change high DPI settings" and the new pop-up window will appear
- In that window you will toggle on the "Override high DPI scaling behavior"
- In the dropdown "Scaling performed by:" you will choose System
- In the last step you will click OK to confirm the setting
- In order to apply the settings you have to restart DewesoftX
