Explained below are the different functionalities that can be used on SIRIUSe device. It is important to pay special attention to the function generator module as it is only available with a licensed option.
When the device is used by itself and connected via USB
Function generator module (synchronous output) | ![]() |
Analog/Digital output (asynchronous output) | ![]() |
Data replay in analysis | ![]() |
Analog signal conditioning function | ![]() |
When the device is used by itself and connected via EtherCAT
When the device is used in a chain with other EtherCAT units (EtherCAT only)
Function generator module | ![]() |
Analog/Digital output | ![]() |
When the device is used in a chain with other EtherCAT units (EtherCAT and USB)
