link to register and use NTRIP:
https://drive.google.com/open?id=1dKja9vjKV-uW-8BL6ZOSt-YT9WRs0kzSyoSvp6qFZgg
When you click on the closest station you will se the name of the station that you need to select:
This client sends data out via a serial port. So you need a USB-RS232 converter. If you connect the converter directly to the DSUB9 port ob the IMU cable it won’t work since it also uses other pins. So you need a DSUB9male-DSUB9female cable which only has pins 2, 3, and 5 connected. Pins 2 and 3 need to be crossed.
I don’t have a device with me at the moment but you need to enable both of these options (latest IMU plugin needs to be used – X3 SP7):
RTK is for the NTRIP input, NMEA is for output of position data and satellites which will be sent to the NTRIP client so you don’t have to manually set the position:
