https://support.dewesoft.com/a/tickets/121561
The main issue is that if you “google” axis multipliers and Kinematic cursors, there were no good answer.
The bearing industry is calling them differently nowadays.
However, those big players have this information available in online SKF, NSK, FAG etc
After selecting the product in the webpage, user need to run “Bearing Frequencies” calculations.
Links:
  1. https://www.oss.nsk.com/calculation/calculate/index/sku/16002-DGBB_SR/
  2. https://medias.schaeffler.de/en/product/rotary/rolling-and-plain-bearings/ball-bearings/deep-groove-ball-bearings/16009-a/p/352647?text=16009-A#Calculation
  3. https://productselect.skf.com/#/size-lubrication/single-bearing
NOTE: Maybe there is better links available, but after selecting the exact bearing, you can run calculations from some buttons there.
Dewesoft Cursors are made based on 1Hz, but those webpages are form RPMs. That what user need to insert there 60 rpm = 1Hz.
After that you can start reading the real numbers
That’s also next tricky part, because then name those difference.
Dewesoft Cage = SKF  Rolling element set & cage = FAG FTFF_i
Dewesoft Rolling element = SKF Rolling element = FAG FTFF_i
Dewesoft Outer Race = SKF Point on outer ring = FAG BPFFO
Dewesoft  Inner Race = SKF Point on inner ring  = FAG BPFFI
And NSK have other names.  However, all are there
