Guide to replicate a previously acquired measurement in writing to a CAN port
First you need to export the data file in .csv format. To do this, you need to go to Analyze, click on Export, and select "CAN messages (*.csv)" as the "Export type."
In order to replicate data acquired from another measurement in writing, you need to enter in "file transmit" the file you want to play back in .csv format, as shown in the following image, and check the box "transmit on start measure"
In order to read the incoming file, it is necessary to import the .dbc file into the can port where these messages are to be read so that the messages that are to be sent can be decoded
