Description of the problem
Here is described which wire color corresponds to pin1, pin2, pin3, and pin4 of the sync cable.
Description of the solution
Below is the pinout of an L00B4M connector.
**Res means that the pin is reserved for a different signal that the device requires. Different devices use this pin for their own synchronization signal.
For example:
Default → PPS
DS-IMU → GPS-PPS
DS-CAM → Trigger
