In order to compare two setup files for a difference you can compare XML files of each setup file with https://winmerge.org/ or such programs. Basically DXS file is written in XML form. To extract XML from DXS there are two options.
Datafile DXD
  • Use any File export
  • Set all export channel to NO
  • Toggle "Export setup to xml file
  • Find XML file in Export folder
Setup file DXS
  • Open DXS with 7-ZIP for example
  • Extract "local.xml" out. This is XML of the setup file
Then compare XMLs with WinMerge or similar program.  Below you can see marked difference in channel name.
