You can either manually run Dewesoft Launcher or enable automatically start-up when Windows is booted. Dewesoft Launcher is located under C:\ProgramData\Dewesoft Shared to run it manually. ProgramData is commonly hidden therefore you should enable Hidden files on C:\ disk before.
To enable start-up, run Task Manager and open Start-up tab. Status column indicate what is the status of RunExeFile.exe. Whether the status is Enabled it means that Launcher will start automatically, in contrary Disabled means that Launcher doesn't run on the Windows start-up.
