From X2021.1 the new Map widget is available in DewesoftX Software.
The new widgets has the only option to import a custom image which must be know as Georeferenced image .TIF
When we build layers from TIF image, we must define the local layers from the folder in which the layers was built.
In our case we have 10 folders and 10 layers must be set when defining them.
1. Add a new layer.
2. Build a layer from TIF (Georeferenced image)
3. Define the path to the TIF file
4. Define the path to which will the layers be built.
5. Add a new local layer
6. The folder containing the previously exported layers from TIF must be defined
It's important that enough level of bounds is defined in our case10 folders was exported for 10 bounds.
