3D GRAPH
- 3D bar graph view type option on 3D graph
Applications And Modules
- Added Modal analysis under experimental features
Devices
- Indication that IOLITE is connected via the secondary bus
Ethernet Receiver
- Added millisecond fraction timestamp decoder
FFT Analyser
- Added an option for frequency integration/derivation directly in FFT
- Added support for linear averaging
GigE
- Trigger condition for DS-CAM600 selected by default
Map
- Chase camera improvements
- Make colouring slots as optional
Math Module Engine
- Added option to add math modules during acquisition
Monitoring
- Removed cursors from the printed PDF report
NET
- Added warning if port is blocked by firewall
Reporting
- Added scrollbar to report settings
- Checkbox to use global time region for report pages
- Enable adding page numbers
Vector Scope
- Added Line-to-line voltages in Vector Scope
- Make clearer distinction between voltage and current
XY Image Graph
- Added XY image graph
