The DS-LED-DISP-VGPS can be directly connected to the IMU1 or IMU2. From both devices, the display draws the power from the USB port. It requires a 5V power supply and because the consumption is very low it can be connected to the IMU device without any problem. Be very careful to connect the display only to +5V. Otherwise, if the display is connected to a higher voltage it will be damaged.
- The pinout on DS-IMU cable:
- Pinout on the DS-LED-DISP-VGPS display:
For the VGPS display to work you need to connect the following pins:
| IMU1 pin number | VGPS display pin number | Name |
| 1 | 1 | +5V |
| 2 | 3 | TX AUX |
| 3 | 4 | RX AUX |
| 5 | 2 | GND |
In Dewesoft DS-IMU plugin it is necessary to activate the NMEA output:
NOTE:
The connection was also successfully tested with a 5m cable (between the IMU1 and VGPS).
