When the DS-20mA adaptor is connected the amplifier will change its setup to current mode only, then it is hard to see what is going on in the background.
Best to show it is here:
Set amplifier to Current measurement.
The direct shunt is for measuring current, on a sensor that has its own power supply and has current outputs.
Loop powered shunt provides power supply to the sensor and measures current output at the same time.
