In this article is gathered all the data about maximum current output on the DO pin for different devices:
- Krypton 1xCNT:
Output voltage +5V - current limit 100mA,
Output voltage +12V - current limit 90 mA.
- Sirius counter:
The current limit is 5V/100mA; 12V/50 mA.
- Dewe-43:
Sensor power supply up to 10W total:
12 V, total limit 350 mA (Shared between: 8xAI, 8xCounters, 2xCAN)
5 V, total limit 700 mA (Shared between: 8xCounters, 2xCAN)
+/-5 V Exc., Ch. limit 70 mA
This means that because the channels are not isolated among themselves the pin5 (+12V analog) and pin6 (+12V counter) are connected together - they are ''sharing'' the sensor power supply. All the +12V pins are connected parallel and the current is distributed between them.
- IOLITE PWR OUT:
IOLITE digital input and digital output modules both include power out option, where the unregulated power supply voltage is brought to a 2-pin PWR OUT connector.
The current limitation is 2A for the whole device.
- DO on 4-pin sync connector:
The current limit is 25mA (50mA max 1 second).
