There are three options of Remote pin working modes
1st option: Disabled
- On/off function of Krypton CPU device works only with ON/OFF button on the device
- The voltage on Remote pin is ignored although if changes
2nd option: Remote power on on external pin
- The voltage on Remote pin turns ON the device
- The voltage changing on Remote pin doesn't impact when the device is turned on
- We can turn off the Krypton CPU with button pressing, but device immediately turns on if we leave voltage applied on Remote pin
3rd option: Remote power on and off on external pin
- Krypton CPU stays turned on until there is voltage applied on Remote pin
- Just after we remove voltage, device stars to turn off
Changing procedure
- At first change settings in the dropdown menu in Dewesoft Settings
- Close the Dewesoft and turn off Krypton CPU
- Perform Power cycle - Unplug supply wire and wait for 10 seconds
- When you turn on again, new settings are applied
Signal
- To power the system on, press the
Power switch OR apply a voltage
between 3.6 V and 30 V to Remote-On pin
- To power off the system press the
Power switch or reduce the voltage
on Remote-On below 0.5 V for more
then one second.
