Description of the problem
Can the export properties be set in the setup file?
Description of the solution
When creating setup file, it is possible to set the properties which will be used when exporting.
In the channels list, we can add these three options:
- Exported (defines whether the channel is exported or not)
- Export order (defines the order of the channels in the exported file)
- Export rate (the sample rate of the exported channel)
If these settings were not defined in the setup file, it is also possible to change them in the data file.
To apply the properties to multiple data files at the same time, it is then possible to use the apply action option:
