Description of the problem:
What are the possible scenarios for C++ licensing?
Description of the solution:
C++ script is the Math module that allows compiling your own module for calculation of input channels. In contrast to other math modules C++ script requires licensing. If you would like to use the C++ script but you're not sure if you have license or not please continue reading this article that describe possible scenarios of licensing.
1. Create setup file having a license without C++ option
Using C++ script is not possible. The option is not greyed-out but when you click to the C++ script module the warning message will appear.
2. Don't have any license or any device connected
Load setup file
DewesoftX switches to DEMO license mode that enables C++ Script option. If you create a setup file and use it with Dewesoft devices later on you would need license as described below.
Export C++ script to bundle
You can open datafile with C++ script, recalculate it, but you cannot export it to the bundle.
3. Have PROF license without C++ option
Load setup file
Loading setup containing custom C++ Script modules will disable / remove C++ script modules from your setup.
4. Have BUILD-IN license
Load setup file
If you have connected Dewesoft device with the BUILD-IN license C++ Script module will be removed from setup file.  You won't be able to create setup file as written in the first chapter.
5. Load setup that have TRIAL license
Load setup file
Trial license includes C++ Script option. You can create setup files with C++ script or use existing ones.
6. Have PROF license with C++ option
Load setup file
Loading setup containing custom C++ Script modules will allow you modify the setup file and measure the data.
You can open datafile with C++ script, recalculate it,  you can export it to the bundle.
7. Have BASE license with C++ option on a DS-DONGLE & Dewesoft device connected (with BUILD-IN license)
Load setup file
8. Have SE license (OPT-C++-SCRIPT option is not possible) without Dewesoft device connected
Load setup file with C++ script
Load setup file with C++ bundle
Loading setup containing custom C++ bundle will allow to measure the data.
Additional information:
