It is possible to automatically copy system files, addons and preferences together with the installation. To do this there needs to be one additional folder “Extended” together with the installer with following structure:
                                                Dewesoft_X3_Installer_x86.exe
                                                Extended
                                                    Bin
                                                        DEWESofttX.exe
                                                        Addons
                                                            addon1.dll
                                                    System
                                                        Project.dxp
                                                    Setups
                                                        Setup.dxs
                                                    exe
                                                        3rd_party_software_installer.exe
Extended folder can contain following subfolders – Bin, System, Setups and exe. Bin folder will copy all files to the Bin folder of the installation. If Addons would like to be copied then an additional subfolder Addons needs to be created. The same is valid also for System and Setups folders. Exe folder can contain other executables which would like to be run after DEWESoft installer finishes (for installing other software or drivers). All files and folders above are optional. If only addons need to be copied then System and exe folders are not needed.
If you're installing the 64-bit version of Dewesoft make sure that the folder names are Bin64 and Addons64.
