Prerequisites
Dewe43 or any DEWESoft device already comes with an embedded DEWESoft license. However if the
customer buys an option (for example a DSA upgrade), DEWESoft will require an additional license.
This manual describes how to embed such a license on the device itself, so that it can later be moved
from one computer to another without a need to copy the licenses.
Implementation of license
In order to embed the license on the device, please do the following:Register the license, as described in DEWESoft’s user manual. Go to Settings and open the Licensingtab. Under the Create new license section, you will find an open field in which you can enter yourlicense number. Please make sure that all devices, to which the license is valid, are connected beforeyou continue. If everything is in place, you can click the right arrow button to start the registration.
If the registration was successful, you should now be able to see two licenses under the Activelicenses tab. One is already embedded in the device (DEWESOFTUSB), while the one that we’ve justregistered gives us two option.
We want to select the upwards pointing arrow, which will allow us to write the license on our device (USB or EtherCAT) that’s connected to the computer.
After you’ve selected your device, there should now be three active licenses in this window.
The new license upgrade is now embedded in the Sirius, and we will now be able to use it on anycomputer that the unit is connected to, without transferring the license file.If we want, we can delete the .lic file, which was created during the registration on our computer. Wecan however keep the license file, which will allow us to use all of its functionality on this computer,even when our hardware is not connected.
Removing the license file
We can also remove the license file from our device by clicking on the x button, and confirming the
action in the dialog window that pops up.
IMPORTANT: This operation can’t be undone!
